Yes I'm running passive. But my rear speakers are running off the head unit. I did the ta/auto eq again and the measurements changed drastically. Front left was around 38" and went to 60". Front right was around 60" and went to 85" rear left was around 40" and went to 80". Rear right was around 80" and went to 160". ????
I read the article in the other forum and I don't think I can do that since I'm running passive on my components. After the second ta, I had to turn all the eq frequencies down. Especially the first three bass frequencies. I have them as low as they will go. I made sure the "Q bass" on my amp was all the way down and I turned down the gain on the amp also. I am not using any xover on the amp and the -12db slope on the amp is turned off. Also I have the cdt xover set to flat for the tweeters. It has a -3/0/+3 slope. I have the front hpf set on 100hz at -12db slope. And the rear hpf set at 125hz at -12db slope.
