Help setting the HPF and LPF on my amp
i'm lost.
thats what i thought we were talkin about.
what are you running? a sub and some components?
just mids, tweeters are going straight to HU. Now the mids are going to the amp, my question is do i only set the LPF setting or the HPF setting also?
well active is actively crossing over both the mids and tweets. mids should be band-passed. tweets should be high-passed.
i'm just trying to figure out what you're trying to do. i don't really understand.
ok sorry, i am just going toamp the 6.5" mids and my tweeters powered by my HU, all i want too do is set the setting correctly on my amp for my 6.5" mids. the amp has a switch for low pass, full, high and has two dials, onee for HPF and the other LPF...what should they be set to appoximatly?
Hi-pass.
say you set it to 60hz, it will play everything ABOVE 60hz
Low-pass
Set it to 60hz, it will play everything LOWER than 60hz.
You adjust which ever filter you decide to use.. I would use the hi-pass
xDATx
xDATx
Los Angeles, CA
xDATx
