4 ohm vs. 1 ohm efficency. which is better??
usually running amps at higher ohm loads results in a higher efficiency. but i mean if the 3000 watter is more efficient than the 2 1500 watters, even at a lower ohm load then i would go with the 3kw amp.
it depends, but CHANCES are that the ones ran at 2 ohms will be better off than the one ran at 1 ohm.
I've never known MTX to have unusually efficient amps.
Without a very thorough bench test I really don't think there's any way to know which would be more efficient.
I do know MTX's are conservatively rated, so if the other amp is closer to accurate, or over-rated it may be less of a strain to your alternator even if it's just middle of the road in efficiency.
I know I've seen efficiencies on some cheaper class D's in the 80's at min impedance and some higher end D's around 70 at higher than min. impedance.
OoMesKoO
Me > Newbs. :fyi:
OoMesKoO
Rhode Island
OoMesKoO
