Help setting LPF, HPF and SSF with CC-1
Hey guys I just got in a SMD CC-1 and wanted to set my crossovers, but I'm clueless as to what I should be setting them at.
I'll list the tracks on the cds if you could let me know what I should set them at for a 15inch bandpass 4th order sub. Amp- BRX 2000.1D
LPF=?
HPF=?
Subsonic=?
cd1.
Track-1--14hz
Track-2--16hz
Track-3--18hz
Track-4--20hz
Track-5--22hz
Track-6--25hz
Track-7--28hz
Track-8--31hz
Track-9--35hz
Track-10--40hz
Track-11--45hz
Track-12--50hz
Track-13--56hz
Track-14--63hz
Track-15--71hz
Track-16--80hz
Track-17--90hz
Track-18--100hz
Track-19--112hz
Track-20--125hz
Track-21--140hz
Track-22--160hz
Track-23--180hz
Track-24--200hz
Track-25--225hz
Track-26--250hz
Track-27--280hz
Track-28--315hz
Track-29--355hz
Track-30--400hz
CD2 has track 1-30 from 450hz to 12.5khz
I'd start at 80 high,80 low...ssf around 20.
I thought I had a HPF but I was wrong, I set those values with the CC1. I checked my HU clipping level and set my amp gains using a DD1, so when I just tested my system I felt like the subs were way louder than my vocals. Should I raise the gains on my door speakers or lower the gains on the subs? Or do I need a better setup for my door speakers?
kicker 350.4
front door DS652 (I think)
rear door CS65 (I think)
speedyjuarez
Premium Member
Premium Member
speedyjuarez
Live in Hobbs, NM. From Ft Worth, TX
speedyjuarez
