Immortal
EDIT: Please see my last post as I tend to ask more questions as I go along
Quick questions guys, I had circuit city set up my system a few months ago and now I want to replace the amp with a bigger/better one since I have more money.
I have two amps, a 1000 mono for the subs, and a 100 x4 Channel for the speakers. The thing is that the guy set up the 4 channel amp to only use 2 channels bridged.
My immediate goals are to upgrade the 4 channel, then the speakers, then the mono bloc, in that order, to increase the volume that I am pushing.
My first question is, do I need to buy another 4 channel or can I buy a 2 channel instead? Would I want to do this? I'm just thinking that I might be able to get a more powerful 2 channel for the same/cheaper price, and if its just a matter of switiching out the amps....
Second question. I want to get a significantly more powerful amp to replace the 4 channel and possibly another for the mono. I'm thinking Fosgate Power series in the 400-600 watt range for the 4/2channel and maybe something in the 1000-1500 range for the mono, perhaps replacing the cheap mono amp with a Fosgate 1000, which is already underrated in RMS to begin with. The bass is fine so the mono is a lower priority because my goal in upgrading the amps and speakers (read down) is to get louder volume from the music to compete with the bass.
Third question. What kind of wiring gauges and quantities am I looking at here? I have a 2004 Ford Escape. I imagine ill need to upgrade the primary power wires running to the engine and possibly the speaker wires. Thoughts?
Fourth question. If I do upgrade one or both amps, am I going to need anything else like another battery, capacitor, etc? Any detailed information on this would be appreciated.
Finally with the more powerful amps I am going to go ahead and buy new speakers too, 110 RMS each (I have 50 RMS each right now). Will the new amps support them? The Fosgate P400's push 200 RMS x 2channel at 4 ohms bridge so I suppose they will. Do you think ill see as huge of a gain in loudness as I am hoping for by upgrading so significantly?
Thanks in advance for all the help.
