Help rebuilding a sub
My63bug
So I picked up this 12. It has a busted tinsel lead.. I was thinking about rebuilding it. Beefing it up making a custom. any ideas where I can get information on. What can be done with this motor n basket
Old School Re. Basket is common. Likely a 3" coil. It will be a fairly flexible platform although I would try to keep moving mass from getting out of control and would try to keep the suspension fairly soft. It really depends on your goals though.
x2 if you just want a really good recone kit you can go with fixmyspeaker
and maybe Fi. Havent kept up with things the past couple years, but if Scott is still around he may know or thing or two about that driver ;-)
Cant get pn fixmyspeaker anything I click on it asked me for username and password. I don't even know how to register
It's a 600w RMS sub. I'd like to double the power handling if that's possible
Likely they put in as big a coil as it can fit or as the motor can really control. Assuming that's an honest rating it's thermal not mechanical limited.
If it's just a broken tinsel you can probably repair that.
try messaging them on facebook looks like their website is broken for some reason
looks like their page actually says its down for upgrades as of last night
almost every recone ive seen on older RE's is psi. if the gap is large enough you can fit an 8 layer 3 inch coil but i doubt it. pull the soft parts out and measure it with an accurate caliper
544
557
I went with Kenwood Exelon. Audio Control amp and speakers. It’s amazing! I’m glad I did some research before buying. Thanks guys.
636
My63bug
My63bug
Vacaville ca
wew lad
Decebal
    Jun 10, 2024
