HELP rcs's or amp HELP
Abc123Abc
BOSS
355
WI
okay i just bought a hifonics 1600w a month or 2 ago and all of a sudden today engine noise just started to happen. it goes to the rpm's in my car, im saying its pretty loud too. when i take the rca's out of the amp its not there. then i found out when i press them in pretty hard into the rca port or w/e the noise stops. so what do you thinks bad my rca's or amp... thanks
this is a long shot but just because this happened to my buddy recently with close to the same symptoms i will though it out. check the RCA inputs on the amp and see if the feel loose or see if the amps casing feels loose if so your rca's inside the amp may be grounding to the amps chasie.
Abc123Abc
BOSS
Abc123Abc
WI
Abc123Abc
Mike Mccabe
