Help understanding power of sub tones (Using scope)
mledez
Hi,
I had some time with a big question !! posted in other forums without a good explanation
I use tones to set the gains of my amps... as a rule always used a 50hz tone 0dbfs, but I tested 100 90 80 ... 30 hz and noted the lower the freq the more power the amp gives... so if I use a 50hz tone to set gains what happens when a 30hz signal comes from the deck ??? I think the signal goes clipped
I think is because of the required energy to produce low notes, more cone movement so more energy... But I really don't know the real explanation, aldo Why is the more acurate method to use ??
Thanks,
Miguel
Don't look my english please
Is it possible that your crossover slope is causing this issue? //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Using -18db/oct low pass integrated in pioneer HU, But I'll try turning it off
Thanks
You were right !!! Not the slope, the crossover was at the opposite direction... The amp doesn't have on/off for xover... so instead of rotate al the way to the right was on 35hz
mledez
mledez
Venezuela
mledez
Mike Mccabe
