Help Please
  • 5
Heel4lyfe
home
Can someone explain to me why my wire did this...
it was connected to my APSM 1500 using 2 of the aluminum inputs from toolmaker
Over current, bad connection, cheap wire
its KNU flex 4 ga. thought that was pretty reliable.
if it is over current. should i just upgrade my fuse??? and lastly could it be a bad ground?
No you cant. If you use larger then a 150 amp the cable could catch fire. With that amp I would use 1/0 and it could be a bad ground. Make sure the gain is set right
looks like i will be installing some of that 1/0 AT wire i got a while back //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Heel4lyfe
Heel4lyfe
home
mylows10
