Help Please
Heel4lyfe
Can someone explain to me why my wire did this...
it was connected to my APSM 1500 using 2 of the aluminum inputs from toolmaker
Over current, bad connection, cheap wire
its KNU flex 4 ga. thought that was pretty reliable.
if it is over current. should i just upgrade my fuse??? and lastly could it be a bad ground?
No you cant. If you use larger then a 150 amp the cable could catch fire. With that amp I would use 1/0 and it could be a bad ground. Make sure the gain is set right
looks like i will be installing some of that 1/0 AT wire i got a while back //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Heel4lyfe
Heel4lyfe
home
mylows10
