Help please!
I would assume that the 501s would be for the subs and the 501x for the highs.
The 501x would probably be a good choice for the highs, however you may have some problems wiring the 501s. I would assume you'd want to bridge it and give it a 2 ohm load (two 4 ohm pioneers in parallel). This amp won't be able to handle the 2 ohm load when bridged. You may want to look into the 501bd from rockford if that's the brand you like.
However, I could easily be mistaken in my assumption that your subs are 4 ohms each. If they are 2 ohms or dvc 4 ohms, then your 501s could still work.
bmwgirlie
bmwgirlie
Midlands, UK
DirtySchemer
