Help picking an amp
  • 4
Ok so I have Kicker 44KSS6704 ( KICKER | KS Series 6.75" Components )installed in both doors and rear deck and I also have two Selenium D250-X Phenolic Compression Driver ( D250-X ) I'm looking to install. Can someone recommend me an amp that can power all this with no issues.
Sent from my iPhone using Tapatalk Pro[/quote
I see a few issues with this. The 1st is comps in the rear deck. I mean it's ok but most of your sound comes from the front. Some people just put 6x9s or so back there. The other is compression drivers. Not needed imo. Gonna have way too much tweeter going on to be able to keep up with the Kickers. Do you have any subs?
PPI has some good amps to choose from and are typically around 100 bucks.
Yeah I have two 12's in the back that are fine and I installed one set of tweeters
Resonix is supposed to be the bees knees, but it is a little $$. If I was doing the whole car, probably would shell out for the entire resonix...
25
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
973
Im sure you could find a great deal on here as well for your mids and highs. Just another great speaker to be considered. Audio Frog may be...
962
KILL3RCOOP3R
KILL3RCOOP3R
US
BOOMINGRANDPA
    May 18, 2024
    May 18, 2024
