help on wiring 3 subs to one amp
jjoven1225
NJ
im not really familiar with running three subs... ok my frind has three cerwin vega 4 ohms DVC sub. i believe there's around 190-200 RMS each... i have two amps.. MA audio 600 watts and ultra linear ul600hc...which one should i use and how should i wire them to make the loudest .. if i use the MA Audio, how should i wire them? if i use the ultra linear how should i wire them?
here's the spec....
MA Audio is 2 ohm stable stereo
2x150 RMS
2x300 MAX
UL600hc is.....
2 x 300W RMS @ 4 Ohm Stereo
2 x 500W RMS @ 2 Ohm Stereo
2 x 1000W RMS @ 1 Ohm Stereo
2 x 1200W RMS @ 0.5 Ohm Stereo
1 x 3000W MAX @ 1 Ohm Bridged
Maybe my mind is still to foggy but the pic and the numbers didn't seem to work. You could however run them all in parallel in stereo @ around 1.33 ohms. That would get you your 200-300 watts per sub if not more.. Just use a crossover to set it for a mono output and you'll have no probs with channel seperation. er competing channels or something like that.. I need more coffee.
Mike
jjoven1225
jjoven1225
NJ
Woodmister
