Help on setting gains...
turnstylez18
k i just set my gains my amp since i got a multimeter...i have a monoblock amp...doing a 4 ohm load..on the birthsheet its 614 rms....so it should be set at 49.5 volts....when i tried using a multimeter it didnt give whole numbers...it was "0.145" for example....so i set it to 0.495...i dont know if its right....or if thats how the multimeter is..what do u guys think? thanks
i used the ac voltage setting ..."V" with the squiggle on the top...its right next to the off setting in this pic
pfft...auto ranging meters...what a luxury //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
In that case, it should be reading larger numbers.
You're measuring at the amp's output terminals using a test tone, correct?
Call me an idiot
"IDIOT"
but I never actually knew that.
Live and learn.
Hmm.......
Next hurricane season I might hook up some appliances to my amp when the power goes out.
Wonder what kind of music I will need to play to run the TV?//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
P.S. Sorry for the hijack but I seriously wasn't aware of the fact that the amp is a converter.
turnstylez18
turnstylez18
Toronto
Rattlebrain
