Help on electrical backup?
group 31 is a size of battery. the batts you want are ~$250 each or so (AGM deep cycle). Alt will be ~$400-500. Front batt AGM will be around ~$200
oodles of 1/0 wire and terminals and ANL fuse holders
yea, i agree with the estimate above of $1000-$1200 for electrical. that's more than all four amps! gotta pay to play. otherwise, you might as well just eliminate half your subs/amps cuz the voltage drop you'll get will negate the extra gear.
should have just got 1 amp to do that power,then you would have needed less batteries
not necessarily less efficient to have four amps vs one amp. certainly, total current is 1/4 per per amp, which helps efficiency. but wiring would have been much simpler. power and ground wiring will be a chore, even a great installer would be tasked to make it right. i would probably spend 10 hours just wiring the amps - including wire routing, protection, terminations, battery connections, etc.
here is a great Group 31 battery: Platinum Marine Battery - Group Size 31M (Price with Exchange)- DieHard-Automotive-Batteries-Marine Batteries
ha. i hear ya. when i was 16 i had multiple amps and four subs as well. so i know where you're coming from. what i didn't know back then was that i needed an electrical system to support my equipment. you're lucky enough to have forums like this where you can get advice, see build pictures, etc. back in the 90's my only references were magazines, local shops, and friends who didn't know jack. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i have 3 amps currently. but only one is for subs. two are for my front speakers. i have literally spent dozens of hours wiring the amps, perfecting routing. see my build log for some ideas on how to wire multiple amps and not have it look like a spider's den. wire management is important. work on proper wiring methods now and it'll help you throughout.
take pics along the way, of every step. pics keep you honest. if you are embarrassed to show something, fix it. detailed pics of my builds was one of the best things i've done and it's helped me be a much better installer.
96 lude
96 lude
Florida
96 lude
vegang
vegang
