Help me with Fusion FJL-1611D Please
Cmccloud
I just purchased a Fusion FJL-1611d nd need some help. I got a 15" L7 Dual 2 ohm and anytime I wire it to 2 ohm it shuts the amp off after a few seconds of bumping. But if I wire the sub to 4 ohm it bumps and sounds pretty good. Why would this be, the amp is supposed to be 1 ohm stable(actually 1/2 ohm stable) and plenty of power.
Store | Company | Contact Us | Email Product List | Log In
Fusion Car Audio
Email this to a friend
Fusion 1 Channel D-Class Linkable Amplifier CEA 2006 Rated FJL-1611D
Part #: FJL-1611D
Your Price Qty
$999.99
Detailed Description
1 Ohm / 2 Ohm Stable Linked
CEA 2006 Amplifier Power Standard Compliant
FUSION Regulated Amplifier Technology (F.R.A.T)
FUSION Intercooled Semi-conductor Technology (F.I.S.T)
FUTRANZ Efficient Heat Sink Transfer Technology
Gold Plated 4 gauge Power and Ground Connections
Gold Plated Audio Input and Output Connections
Gold Plated RCA Output for Multi-purpose installations
F-BASS Remote Controller Compatiable
Product Specifications
Bandwidth 10Hz - 50kHz
Signal to Noise >95dB
Fuse Rating 4 x 30A
Separation >60dB
Input Sensitivity 300mV-8V
LP Variable Crossover 40 Hz - 240Hz @ 24 dB / octave
HP Variable Crossover 40 Hz - 240Hz @ 24 dB / octave
Variable Bass Boost 0dB + - 18dB Gain @ 45 Hz
Variable Sub Sonic Filter 10 Hz - 55Hz @ 18dB / octave
Input Impedance 20K
Damping Factor >200
T.H.D 0.06%
Dimensions D 65.5mm L 468mm H 276mm
CEA 2006 Compliant Amplifier Ratings
12.6 Volt Power Output Specifications
600 WRMS per Channel @ 4 Ohms and 1% THD+N
900 WRMS per Channel @ 2 Ohms and 1% THD+N
1250 WRMS Bridged Channels @ 4 Ohms and 1% THD+N
14.4 Volt Power Output Specifications
840 WRMS per Channel @ 4 Ohms and 1% THD+N
1250 WRMS per Channel @ 2 Ohms and 1% THD+N
1600 WRMS Bridged Channels @ 4 Ohms and 1% THD+N
Linked Power Ratings @ 14.4VDC
2850 Watts RMS Linked @ 4 Ohms
3400 Watts RMS Linked @ 2 Ohms
I have a stock alternator and a regular battery with 4 gauge to the back. it's in a 87 cutlass. Any help would be great thanks.
If its a dual2 you can't wire it to a 2ohm load. You can do one coil on each side and get full power from your amp. Its a 2ch amp and its not stable bridged at the 1ohm load I suspect you're trying. Thats why it goes into protect.
Put one coil on each side or run the positive from one side and the negetive from the other side bridged to the amp and then connect the odd positive to the odd negetive for a 4 ohm load. That gives you max rms and should run just fine.
The amp is supposed to be 1 ohm stable, so it's not? I tried running a 1 ohm load bridged and not bridged and the same thing happened both ways it just goes into protect after a few seconds. I played it in 4 ohm but I just figured it would be better in 1 ohm, but not if the amp can't do it I guess. That's bad a **** $1000 can't hold a 1 ohm load? wtf
Hey guys, think it might be that my electrical is not good enough to run it in 1 ohm, all I have is a reg battery up front, 4 gauge front to back and a stock alternator? you think so?
my brother has one, he has it running in 2ohms per side, i think it is internally brighed at 4 or 1 ohms, i.m not sure
Even tho this thread is old, i just came across it and wanted to point out for this guy and others who may not know. Its NOT a 2 channel, and its not "internally bridged" Alot of mono amps have two pairs of speaker outputs for ease of connecting mulptiple subs. I know most everyone on here knows this, but obviously some people dont.
Cmccloud
Cmccloud
LaFollette, TN
westman995
    Jun 20, 2026
    Jun 20, 2026
