HeLP ME wire my sub......
Wire the sub like so:
It doesn't matter which of the terminals on the amp you use as long as whichever ones you do use are appropriately wired for polarity (Pos output terminal to positive inputs on the sub and then likewise for the negatives)
OR - since you're wanting a parallel-wired configuration for your DVC 2 Ohm sub to achieve a nominal 1 Ohm load you could simply wire one coil to one set of terminals on the amp and the other coil to the other set of outputs on the amp. The same result is available either way.
ok...that is like im saying in my post correct............postive from the amp to positive on coil 1........negative on amp to negative on coil 2
The positive output on the amp needs to be connected to the positive input on both coils and likewise for the negative output on the amp to both negative coil inputs on your sub.
ughhhh...still dont get it................am i running two positives and two negatives....from the amp to the sub.......or is it one pos. and one neg
yea......from the pic i see one wire coming from one of the positives on the amp to one of the positives on the sub..then it looks like a cut a short piece of wire and run it from the positive on one coil to the positive on the other coil
Exactly correct. Do it.
bow125106
bow125106
arkansas
j3bus2k3
michigan born
    May 14, 2026
michigan born
    May 14, 2026
