Help me pick an amp
jiggyman
I'll be running an active setup with xxx6.5 mids and some still unknown tweets(recommendations?). I just need a 4 channel amp that will do the job.
Sorry for lack of info, but any help would be appreciated.
Would an ed 9.4 work? since im already getting a 9.1 for my sub? What other options do I have?
How would the 9.4 compare to that mb quartz amp?
as for the 9.4 its:
65 x 4 @ 4 Ohms Stereo
100 x 4 @ 2 Ohms Stereo
150 x 2 @ 4 Ohms Stereo
Subsonic Filter : No
Low Pass Crossover : Yes
Current Protection : Yes
Length : 12.00
Width : 9.85
Height : 2.25
mb quarts:
100 watts RMS x 4 at 4 ohms (200 watts x 4 at 2 ohms)
» 400 watts RMS x 2 in bridged mode (4-ohm minimum impedance)
» CEA-2006 compliant
» front and rear high- and low-pass filters (variable 50-500 Hz at 12 dB per octave)
» multiplier x10 switch converts filters to variable from 500 to 5,000 Hz
» LED clipping indicators
» preamp-level inputs and outputs
» front end defeat bypasses gain and crossover controls
» fuse rating: 30A x 3
» requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
» 11-1/2"W x 2-3/8"H x 16-3/4"D
» warranty: 1 year
Any other options? is 100 watts enough for each xxx mid?
maybe grab the MB Quart 4 channel on sale at Crutchfield
I like teh six channel amps, like the audiobahn 6601, just so i can have independent control of the Highs, Mids, and Tweets.
uh. //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
highs, mids, and tweets?
high = tweet IIRC //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
midbass, midrange, and highs\tweet\treble you mean //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
sweet thanks alot, i'll definately look at those. I'll wait a little bit though, since that Mb Quart amp wasn't around, I just bought a ed 9.1 with one of those $50 off codes for my xxx.
Just bought a coustic xm6 too so im getting closer to install time. Wiring and 1 more amp is all I need, can't wait.
jiggyman
jiggyman
Edmonton, AB
jiggyman
vegang
vegang
