help me pick a 5 channel plz
The Boston is rated for slightly more power and is a good bit cheaper.
The Polk is stable to 1 ohm on the sub channel and a bit smaller.
If you dont need 1 ohm stability on the sub channel, and have the space, go Boston; if u need 1 ohm stability and have the extra cash, go Polk.
The Boston is rated for slightly more power and is a good bit cheaper.The Polk is stable to 1 ohm on the sub channel and a bit smaller.
Is the 1 ohm the put more strain on the amp and the boston being a ab/d hybrid worse than a class d only . Also size dosnt matter really cause it mounts to the back seat but is the polk better brand or is that amp better for being a class d
I linked you to one in a earlier thread that was decent and cheaper...
I only buy from my local shop there good people and charge me 10 percent above cost so thats why i look at these 2 also mn quarts is owned by sonicmaxx which isnt good company
Just because one company makes different brand products doesn't make them all bad... just like appliances for the home.. whirlpool, GE, etc.. have many other sub-companies that they sell the same product just under a different name some are good some are bad.. same goes with car audio eq
You can get the Boston a bit cheaper online...
Maybe a couple bucks but not alot to deal with online shipping etc i also like to support my local guys. The polk i havent seen cheaper tho and it can handle a one ohm load but i really dont know its so tuff
mdsniper7
mdsniper7
tampa fl
nismos14
