Help me I'm Car audio STUPID
To start off... I did do a few searches with no good outcome. First post... blah blah blah..
I drive an 04 Element DX, I listen to all sorts of stuff... Mostly Metal and hard rock... I obviously own a zune and i want it in my car. This is what i have come up with so far.
Blaupunkt HU MP47 or MP57 (depending on what kind of deal i can get on the 57)
I need the Aux port on the front, I like the color change thing and the Euro tuner (military so god knows where i will be next)
Now, I want more bass (keep in mind i dig metal and double bass is just wicked)
First i thought of getting the Basslink II, What kind of bass does this put out?... i need that Punchy tight bass (again think metal) My other thought is to go with a single mono 10"... Blaupunkt Vw1000 has good ratings... now if i go with that... How much amp will i need? (this is where i am stupid) Crutchfield reccomends at least 70% of the max RMS... is this true, and what would you suggest? could i run it on a single mono 500?
Thanks for the help...
here is what i ordered
RECIEVER: Blaupunkt Hamburg MP57 CD Receiver
SUB: Blaupunkt VW1000 10" Component Subwoofer
AMP: Kenwood KAC-9103D 900 watts RMS x 1 at 2 ohms
Wireing kits included... am i missing anything?
You will enjoy the Blaupunkt Hamburg MP57 receiver. Has very good control over the volume increasing and decreasing it in smaller steps than a lot of head units do. Don't think you will have a problem with this since you're only using an external amp for the subs, but on my system I had to isolate the antenna cable ground from the receiver as I had a nasty ground loop. Has no affect on reception.
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif what's this post about? you should have asked before calling your stuff //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
you'll need an amp wire kit. (rca+speaker wire+fuse holder/fuse+terminal)
knuconcept has the nicest one for cheap. there is cheaper, but quality sucks
ReaperZune8
ReaperZune8
All over the place
bw_audio
