OP
Nathan32387
- Thread Starter
- #31
i dont have any deadening at all, was hoping i could get by without it as long as possible, then whenever i decided to add it, it would just make it that much better, maybe it was because i had the port forward, maybe that just doesnt work to well in my car, when i had it rear facing it would have about 3-4" clearance from the tailgate, and it made the tailgate flex the most ive ever seen in a vehicle, i was doing hairtricks at about 21-22hz, when i flipped it i lost so much low frequency extension, up to about 28hz, but i did it because it sounded better at lower volumes.if you could only get 146 out of previous set up, i think you need to play around with diff. boxes & maybe consider upgradeing electrical. with previous system you should have been able to do 150 on music w/ proper electrical & box. you also may have some cancellation issues with the car. do you have the car properly deadened?
