KTMrida4life
So heres my current setup
3 SA 8s on a SAZ 3k wired to .67. Subs back, port back, slot port 2.25" x 11.25". Box is tuned to 33hz.
It did a 138.5 on the meter 41 hz, which is my peak. 2 months ago when I did this build it was loud at first, now Ive gotten used to it and want way louder.
Heres the box dimensions I have to work with. I will double check these today. These ARE INSIDE THE MDF dimensions.. meaning I have accounted for material thickness with these specs. I will double check these measurements tonight though in my trunk. This also will leave about 4-5" of room between the trunk and the left side of the box for a side firing port. The 12.5" depth does NOT leave room for rear firing subs as I am considering doing sub up port side.
This is roughly 4.5cuft.
This my trunk right now.
With this air space, and trunk.. if I want to get as loud as possible off the same power (SAZ 3k) what is my best option?
6 SA 8s, or 2 beastly 12s like nightshades?
Need help here. I want to do a 145+ :confused1:
