Help me choose mids
The Dayton RS has better parameters for IB (no enclosure) mounting, a higher X-max, and has a better cone material (aluminum > poly, IME) for transient response.
The only caveat, is that the RS is a little harder to crossover... there is a breakup peak in the highs, in all aluminum cone drivers, that poly won't have. If you don't feel up to custom-tuning a passive crossover (trap filters to notch out the peak, etc), then the TB will be easier to deal with, with out of the box crossovers...
Regards,
Gordon.
Just curious...why are you going to run 3-ways? I'm in the same spot but dont have the crossover to do it yet...
My vote goes to the Dayton reference though.
This would be a decent amplifier to run on what you have. I would spend a little more and get the 460.4 if you can swing the extra funds. Ive...
Sub should be in the cargo area for best results. I'm skeptical about those unknown brand Chinese head units myself and would stick to known...
I am upgrading standard door & dash speakers in a VW T5 camper (2005) using a plug and play upgrade bundle, continuing with the two-way setup...
206
FoxPro5
Causal wanderer
FoxPro5
3 octaves higher
khail19
