vario
digidash hit the gas...
I just bought this sub: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=295-470
t/s specs:
*Power handling: 250 watts RMS/350 watts max *VCdia: 2" *Le: 2.30 mH *Impedance: 4 ohms *Re: 3.1 ohms *Frequency range: 20-500 Hz *Fs: 20 Hz *SPL: 92 dB 2.83V/1m *Vas: 9.70 cu. ft. *Qms: 4.00 *Qes: .50 *Qts: .44 *Xmax: 8.5 mm *Dimensions: A: 15", B: 14", C: 6-3/8".
and this amp:http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-805
Bass Boost 6dB @ 30Hz
* High power/low distortion
* Adjustable low pass crossover
* High and low level inputs/outputs
* Auto On/Off
* Phase reversal switch
* Power output: 170 watts RMS @ 8 ohms 240 watts RMS @ 4 ohms
* S/N ratio: 90 dB (A-weighted)
* Dimensions: 9-13/16" W x 9-13/16" H x 5" D
I am thinking about building a vented box, but I am also considering sealed. Main things I am looking for are accuracy and sound quality. This is for my room, not my trunk. I am willing to paypal $5-10 if someone can give me a really nice plan. Should I go vented or sealed? I have already bought these parts so that is what I will be using. If I go vented, I would either go slot port or flared pvc.
Prefered size range is 2 cubic feet to 4 cubic feet, possibly larger if I like the design.
Material is birch plywood, not mdf. I don't like cutting mdf. I will reinforce of course.
Will a slot port give me the accuracy I need for home audio?
t/s specs:
* Auto On/Off
