IA DP 15" Enclosure
lambo37
SD
So this is for a old model incriminator audio death penalty 15....in a trunk, trunks max dimensions are 14" high, 37" wide, and 30"or so long.
Box width 25”
Box height 12”
Length 26”
Box Volume 3.88 cu ft
3- 4” aeroports, at 8.86 in. ea
sound ok?
Im gonnna flush mount the sub, and vinyl it...paint ports white...
Its upfiring sub closest to back seat, and ports back..(is this most likely maximum output?)
thanks
exactly what frequency are you trying to tune it to? it's going to be in the 45-50hz range with that box size. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
32 hz.............i used precision ports site? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
i must have done it wrong..........can someone help me out
using the psp calculator each port would be 22.65in long, and if flared on the end they would be 23.65. That would get you to 32hz tuning
OH i thought you divided that number. shit. the ports are only 17 in long on pe.com //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif maybe ill rethink my port plan. thanks alot.
lambo37
lambo37
SD
lambo37
