akheathen
Premium Member
trianoacitol contraceptiv
umm......, yes, actually, you should use a dmm to check the voltage at the amp. turn it on and let it idle(no music playing.) compare the power at the amp terminals with the power at the battery. move the positive probe from the positive cable in, to the remote in. it should be pretty much the same. if you find more than minor discrepancy, then you have a bad connection there. if not, do the same with it playing. also, make the same comparison between the terminals, and both sides of the fuse. there should not be a voltage drop. finally, measure your sub resistance, could have lost connection to a coil, or even pushed one over the edge with your new adjustments. check the ac output voltage....... good stuff to start with there.... oh, and you can rule out rca problems( which are likely from movement, if present) by using a 3.5mm headphone jack-to-rca cord and a portable player and see what it does.
