audioholic
not a moderator
Im not trying to single you out and pick on you, I swear Im not. lol Maybe its jsut Im not use to how you word things, but you made another statement in this reply that strikes me as odd at best, and incorrect at worst. Im 100% with you in agreement on headroom, but you lost me when you said this: "Setting the input sensitivity to compensated for a desired volume makes everything sound compressed...to me at least."Follow those JL guidelines and set the gains. Now, hook up your o-scope and look at the graph...see any clipping? You will...lots of it. JL's regulated amps can "hide" clipping very well as that's what make a good amp a good amp.
Gas the amp the old fashioned way using an o-scope and you'll wonder where all the volume went. The amp will still be maxing out, however, your average power has gone down. That's the "volume" people often think of when they think a system is loud. Personally, I like a lot of headroom. I want a whisper to sound like a whisper and a kettle drum to sound like a bomb just went off. Setting the input sensitivity to compensated for a desired volume makes everything sound compressed...to me at least.
It's also important to keep in mind that some amplifiers are very tightly regulated and can be set up w/a volt meter. Other amps cannot be set up this way, the output channels need to see a load and output can vary based on the vehicle's voltage. At rest, idle, and the RPM in which the alternator is at maximum charge will yield 3 different voltage readings on an unregulated amp.
JL is a good company with many bright minds & great product. But their 'way' of doing things, such as the links you've provided, should only be applied to certain products and looked at as a 'general' guide. It's a way of doing something that'll work for most people most of the time. In that regard, setting your radio at 3/4 volume and listening for the woofers to clip also works for most people most of the time.
Just b/c it works for most people most of the time does not mean it's the correct way...to me at least.
Im confused because you start off saying you like headroom, but then say you disagree with gaining an amplifier's output down to reach a desired volume level... which is how you correctly set up an overly large amp with lots of headroom. I dont see how else you would suggest obtaining/using this headroom (remember, headroom is power that is only used for momentary peaks in current demand, think of it like an 'emergency reserve' of power), unless you mean to suggest simply leaving the volume knob on your h/u lower, which results in the exact same output from the amp (including dynamic range, what you seem to be describing as it sounding compressed), but the weaker signal from the h/u means the system is more susceptible to induced noise in the signal chain, and the amplifier's gain will simply need to be adjusted higher to compensate for the lower signal strength.
Lets take a step back and discuss how to properly tune a system when its new. In the most basic terms, what you do is set the gains of each amp/output at or near their peak non-clipped level (be it via your ear, a DMM, or an o-scope). You then determine what are the quietest components in your system (front mids, front tweets, subs, midbass drivers in doors perhaps). Those speakers that are the quietest, are now your reference point. You gain the outputs down on all the other spealers' amplifiers until they level-match the quietest speakers in the system. You now have a system with no audible signal distortion (theoretically), and the power you gained down from the amplifiers is now 'headroom' for those peak demand situations that would have otherwise driven the amplifier into clipping.
