fbi90909
Panty Thief
the lowdown:
today i began helping a friend of mine run a Big 3 and run 1/0GA wire to the back of his 2001 ford escape to hook up 2 kenwood kac-7203.
here's how my wiring is. 1/0 battery to fuse, to trunk, to Knu 1/0ga in to 2x 4ga out fused distro block, 4ga to each amp. then each amp is 4ga ground to frame.
i used the existing remote wire that was already run in the car. also used the existing RCA's that were in the car.
well i sold him my red top and we also switched out the batteries.
here's where i started to notice a problem.
when we first turned the Radio on(car off) everything turned on fine. he then puts on a cd at a very low volume(i.e level 5 out of 30). with that he shows me dimming that happens in his car. now this is the dash, the head lights, the fog lights, and even the amps are flickering like they are getting a shortage of power.
i think wtf???
i take my multimeter and read at the battery and voltage is jumping around like crazy. so i'm like wtf again.
i ask him to pause the music. and the voltage stops jumping and stabalizes itself. so i'm thinking somethings wrong with the wiring of the head unit.
though i have no clue what would cause this. now this is like every little bass note and the lights would just dim BAD. and the music isn't even turned up! shit the amps gains haven't even been set and were set to nothing and the lights were dimming.
i also noticed that only having the system on for 30 minutes and having nothing set while trying to figure this issue all out i find the amps were getting really hot.. i mean HOT. could this be my ground not being suffecient?(i know how to properly prep a ground).
he told me that the initial system that was installed int he car was installed at a best buy, and since then he has had that dimming issue.(i have a strong feeling they ****ed up)
he currently runs one of those motorized kenwood touch screens,but it's a recent HU. he had a different HU installed before and had the same dimming issue.
if you have any guess as to what could cause this please just post a message. i will begin to work on the car again tomorrow after work so while i'm at work i can check the forum and ask questions.
thanks yous anyone?
i think wtf???
thanks yous anyone?
