help emergency
bigv123
i have a 92 eldorado. the previous owner had an after market cd player in it. they wired it from some box in the trunk meaning, power ground remote and acc from the trunk. i never saw it be fore. now the wires got loose all but the remote. and i need help please some one help me get it together
right now i really dont have shop money its a few wires i just know it cant be to hard. it was fine until this *** pulled them loose
Your not being very clear. But you have four wires, i guess from the rear for some reason. Is the battery back there? Anyway you know the remote. So now you are down to three. Testing them for positive negative is easy. You can do it the ghetto way and QUICKLY touch them to the chassis. If you get a spark you have found your positive. That leaves you with the negative and acc. Do the same thing with the acc. If it has power with the key on it will spark when it hits a ground. Or use a multimeter.
no no no. he will probably end up blowing fuses. and not know where do go from there.
//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif :uhoh: //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
You don't even need a multimeter. You can get a test light from advance, walmart, etc for only a few bucks and do the same thing. I had the extra 5 or 6 dollars, I would buy a multimeter anyway as they are good to have around.
Some Cadilacs have the factory radio in the trunk, while the display was in the dash everything else was remotely mounted in the rear. Without the proper tools and little knowledge how to use them, this could take a lot of explaining. Any chance of a snap shot of what you have to work with - anything color coded?
double post
BTW digital multimeters are $10-15 test lights are ok, but in his situation he might need to look for AC if probing for speaker wire
That's retarded....why would GM do that?
bigv123
bigv123
chicago
azbass
michigan born
    May 14, 2026
michigan born
    May 14, 2026
