Help...Durango big 3
tenbux1970
Amateur Gynocologist
Hi,I was looking at doing the big 3 on a 99 Dodge Durango. I was looking at the main power wire from the Alt to the battery...but it goes into a plastic box of fuses,and breakers before it goes into the battery.
Can I run an additional wire from the Alt. directly to the battery ,and leave the stock one in place too?The battery has top and side posts if that matters.
I was hoping to hear that .Did you have the same issue?There is a 140 amp fuse between the Alt.,and battery.I am getting an Ohio Generator Alt soon.Is there a bigger fuse to put in there,or will the bypass take care of that?
tenbux1970
tenbux1970
Mendota,IL
tenbux1970
