help choosing sub
will fox
avon,MN
im looking for a single 12 that is loud but has sq im looking to spend around 250-300 just on the sub i listen to a lot of rap and rock and it will be used daily. i was looking at a rockford t1 or re audio sx 12. it has to fit in a small trunk of a honda prelude.
thanks for any info
Deminsions of space available? And im guessing you want ported? What amp do you have or going to get?
---------- Post added at 06:28 PM ---------- Previous post was at 06:27 PM ----------
Stay away from the newer RE's
ill have to get back to you on the trunk space my car isnt at my house right now. but its pretty small. yea i would like to have it ported. and i havent decided which amp i was thinking hifonics brutus series.
TC sounds is good I'd look at that american bass one that was linked above too. If u got 250-300 for the sub itself dont settle get the best, you can afford some really beefy subs for that. I hope you got a nice amp to give her some juice. I like preludes, what generation is it?
Are you planning to build the box/buy the box/or have one built for you? Because depending on how much rock you listen to, i'd recommend a sealed box or a horn, maybe a 12 Deathbox that thing would decimate if you listen to a fair amount of rock and perfer bass Kick to bass rumble.
its a 01 prelude so the last generation and i plan on building the box im going to draw up some designs tomaro just measured my trunk. the amp im thinking a hifonics 1200w rms at 1 ohm well see
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
10K
Not at all, amplifiers have gain control to attenuate the output to safe levels.
will fox
will fox
avon,MN
will fox
    Jun 1, 2024
    May 31, 2024
