help choosing SQ amp
Thank u for clarifying your original answer. I take back and apologize for my smartass remark. I'm just getting frustrated trying to put together a good system on a budget.
no problem man, i know my answer wasn't the answer you were looking for, so sorry.
i know what you mean. getting a good system on a budget it tough but deff do-able.
i spent under 2 grand on my setup and mine sounds great.
edit: my whole setup including wiring cost a lil under $1500 so far.
tc guy..how do u like your digital designs amp?? I was looking at some used ones.
so far i like them both a lot. gobs of power!! i have an alternator noise i am still trying to fix. thats not the amps fault though. haven't had much time to really play with them. all i have been trying to do was fix the whine. i'm 99.9% sure it's cheap cables.
Hey TC. Try grounding the outside of the rcas at the hu to the hu case. Pioneer has had some issues with the decks, and that seems to fix it. Its a quick and easy test to eliminate the rcas and the HU. Also grounding the HU case has worked in some instances.
already tried it. the only thing that has helped so far was wrapping the rca's in an aluminum foil tape. that means i need rca's that are of quality and shielded.
seriously i have tried everything.
Well, At least you got a handle on it. Whine can be a ***** to chase down. Good luck.
yea i guess my car is just noisy and the noise is being induced through the rca's. i ghetto sheilded them somewhat and the noise got a lot quieter so i guess the answer is new quality sheilded rca's. i'm gonna get some knukoncepts Krystal Kable.
no such thing as an "SQ amp". you could make a hifonics sound good if you know what you're doing.
What the Hell Dose That Mean ?
jamesdean
jamesdean
tampa,fl
zierbox
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
