HELP Can I use 2 types of kicker tweeters and still sound good???? Grade this setup -
socal.2fast
Hi Guys
Please help me out here. I know a lot of people do not care for kicker but I'm getting a super deal on the stuff so I need to stay with kicker. That being said here here is the parts list I'm looking at. It's there top end stuff.
It's going in a 2014 Camaro.
The camaro have the stock speaker spot I was going to mount the Qss67 in and there tweeter as the tweeters are to big and will not fit up in the OEM spot by the window. I was thinking of getting a set of the kicker KST25 1" tweeters to use in the stock OEM spot. Would this sound good?
The QS tweeters are DuPont Tetoron And the KST25 are silk dome
QS Series Matched Component Systems | KICKER
KST Tweets
Kicker KST25 1" soft dome tweeters at Crutchfield.com
1 Kicker 10cvx124 12".
CompVX | KICKER
2 sets Kicker QSS67 QS Series Matched Component Systems | KICKER
1 Kicker KQ30
Equalizers | KICKER
1 Kicker ZXDSP1 front row
FrontRow | KICKER
2 kicker KX400.4. Amps
KX Amplifiers | KICKER
1 kicker 1600.1. Amp
1 qw12150 Speaker wire
Speaker Wire | KICKER
2 QI46 2 sets of 4 ch. RCAs
Signal Cable | KICKER
1 CK8 8g. Amp kit
Amplifier Installation Kits | KICKER
1 CK4 4g. Amp kit
Awesome car! Personally, I would not spend my own money on kicker products, specifically their subwoofers. How good of a "deal" are you getting? If it is from a shop that you do not work at, chances are it isn't a good deal. There are much better products in that price range. Please don't put all Kicker gear in that Camaro!
Kicker is fine unlike what was said earlier. Kicker product is good, just broke people talk **** bc they can't afford it. Same with JL and RF. I don't understand your setup, you have a DSP and a kq30 but no line out conversion. You have 3 amps but only 2 amp kits. I'd go with a zxsum8 into the front row. Get one PKD1 amp kit. You need to get different RCAs too. Don't use different tweeter, make it fit. It's really not that hard.
75% off
Really?
Did you really just compare Kicker to JL and RF? Pff.
To the OP: 75% off is a pretty "well, if its that cheap then why not" area. Kicker's amp kits are great. Oversized wire, good enough RCA's. Their amp's aren't bad either. Just slightly expensive for what they are. It's their sub/speaker line where things get shady. If I were you i'd use that discount on a few amp kits and amps but get some better speakers/subs. It's not worth the bad quality, even at 75% off, and especially in a brand new Camero. 75% off sh*t, is still sh*t.
i did b/c Kicker has been around for 40 years and there products are always of better quality compared to what is out on the market. their prices is the only thing you or anyone can ever complain about. while there are other companies that are up and coming, the only company to compare to Kicker in longevity is RF. considering that RF and Kicker use the same build house for wires, you can't argue that their wires are top notch. RF and Kicker amps have always been the cream of the crop. while there are companies that pop up that have quality equal or better, most of those companies come and go. I've been around the 12v industry for about 20 years. RF and Kicker are always quality. just look at the companies that have popped up in the last 5 years that had better quality subs, amps, etc... and look at how many of them are still around. You can't go wrong running Kicker or RF. The only thing I can say Kicker is a fault for right now is there are not in the PA sector, high powered full range amps sector, or a DSP with and EQ.
So you're telling me Kicker amps are just as good or better than a Sundown Amp? DC? DD? Etc. And no, their subs are mediocre at best when compared to a large chunk of companies out there. The price doesn't justify the quality you get either. RF on the other hand, their high end stuff is still very high end, just incredibly expensive.
I do not see L7s beating out any SA 12s or DDs in the lanes man. Their speakers aren't audiophile quality either. Look at Hybrid audio technologies, PHD, CDT, Morel, scanspeak, focal, rainbow, JL or hertz for speakers man. But still 75% off, cant beat that. Unless they marked it up like crazy. 75% off an item normally worth 400$ and is priced 1200$ 75% of that is still a lot.
yes I am. you put equal to equal power wise and the quality is there. also Kicker's power will be a 2Ω giving their amps a slight edge on efficiency.
as for the lanes, they aren't in the lanes now. they were a few years back. you don't see RF or JL in the lanes either.
for your everyday builds Kicker, RF, JL are all good choices. maybe for your extremes they lose out b/c only RF has 4" coil motors or high powered PA mids and tweeters. not everyone is going to be putting 4 18s with 40k watts of power in their vehicle.
socal.2fast
socal.2fast
So.Cal.
Joseph7195
