Help! Big 3 on a 2012 scion xb
  • 4
I'm getting ready to install my wiring and doing the big 3 at the same time.. Should I add wire for the big 3 or just remove the old wires completely. does any one else own a newer style scion XB that has done the big 3 ? All the help I can get would be great Thanks! I'm using 0gauge knukonceptz kolossus wire in case ur wondering
Normally you can remove the stock engine block to frame (or battery negative, wherever it goes) ground, since there's only one wire. But the other two off the battery you will want to add to, because there's usually a couple wires off those.
Ok I didn't really think it mattered because ground is ground just wanted to be. Sure. So I'll do alt to bat, batt ground to alternator mount, and...
194
470
457
Mike17em
Mike17em
Fontana, ca
Mike17em
