HELP: Best Setup for subs
  • 2
PM_OTT_MP3
What would be the best setup with the following subs and amp:
AMP: Lanzar 245Vibe
2 x 250 Watts RMS at 4 Ohms
2 x 500 Watts Max at 4 Ohms
1 x 1000 Watts Max at 4 Ohms Bridged
2 x 400 Watts at 2 Ohms
Electronic Crossover Network
Bass Boost Circuit
Bridgeable at 4 Ohms
2 Ohm Stereo Stable
Tri-Mode Capable
Frequency Response: 15 Hz-35 kHz
S/N Ratio: 90 dB
SUBS: 2 x Clarion SRW3081 12"
Max. Peak Music 500W
Continuous Power 250W
Nominal Impedance 4/8 Ohms
To all the car audio gurus.... I need your help on this.
Are these the monster's you have ? They are dual 4ohm coils. So I would wire the coils for each sub individually in series for an 8ohm load per sub. Like this
Then wire both subs together in paralell. Like this
For a 4ohm mono load. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
No problem my man. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif If ya have anymore questions or problems let us know //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
One last question, although I'm pretty sure I know the answer... The setup suggested, should be bridged right? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif :confused: //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
2400w x 4 peak and 120w rms x 4. That has to be world record dynamic right there 🤣.
28
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
176
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
533
PM_OTT_MP3
PM_OTT_MP3
Ottawa, Canada
ramos
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
