HELP ASAP! Can This be RE-re-solderd?
Jeeper94
NE Car Audio = Loud Crowd
Got this of deviousone. With or with out the mix up in the first place this still would of happened you can see the feed back post here.
http://www.caraudio.com/forum/showthread.php?p=4876479#post4876479
there are pctures on there of what happened after 2 min play time, what the wire is.. and what it was said to be.. either way I will post pictures here let me know if this can be re-re-solderd or if I have to get a ****ing recone.
Compared to my 10" 8ohm depth Charge sub with MA Audio dust cap before install.
After 2mins play time... sjkdfkjdsahf
And another shot....
What do you all think? Thanks for the help..
get some new tensil leads first
get a razorblade and very carefully remove the dustcap (dont cut thru the cone)
once you get the cap off desolder the rest of the broken lead
pull new lead (after you cut it to length) thru the cone and solder it to the coil
now solder the other end to the terminals on the basket
carefully glue dustcap back on
problem solved
problem solved
this is not for beginners to attempt
x2 this is repairable see if you have a local speaker repair shop they will usually do it for 15-30 per lead, i had my local shop upgrade to thicker, better leads on my old mmats 10" cause the leads were fraying
if he has basic soldering skills and he very carefully follows the instructions i poasted... i dont see why he couldnt do it himself?
Smack the center of the dustcap with a screwdriver or a wrench and carefully peel it away from the glue joint...it'l shatter //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Pull the broken lead through, solder new tinsel to the old lead..glue down to the cone, solder it to the terminal, put new dustcap on it..done //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Edit/ps: You unloaded the sub which is why the lead snapped, might want to adjust your subsonic filter..
duh //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Jeeper94
Jeeper94
Livermore, Maine
casper97ta
