help again, amp wont turn on
motoyfz
Hey. I installed my splw-15 with a friends borrowed pyramid 2400watt amp while I am waiting for mine to come in. Then I tried to install a cheap walmart 300watt mono block amp to power my 2 fosgate 8s. I can't get the amp to turn on, even when taking the wiring off the pyramid and putting it directly on this amp. This is the 3rd one I have tried, and none work. The indicator light shows red and won't change to green. Thanks in advance for your help.
Hey. I didn't try the no speaker thing, but I will try that. The remote line is right because the pyramid amp would work, but that is the only one so far. I also thought it was the ground, but the pyramid also worked, and that is the same wiring onto this amp. right now I have a 4ga ground to 3/8 bolt, so I def. know that is enough. As for the load, I just hooked up a 10" single 4 ohm vc sub, and that didn't help either. THANKS!
motoyfz
motoyfz
st marys, pa
motoyfz
