Help!!!! 99 vert mustang box design
dont go through the trunk. in the back seat, pull out the seat. then ull have 4 bolts 2 top 2 bottom to remove (10mm) then theres a metal strip that goes across bend that up out of ur way. after itsbent out of the way ull be able to slide a box in the trunk a max of 14h x 38L x 20d (the 14high is the highest u can build it and fit it in that way.
Hmm, that's your choice then. Those make nice stealth enclosures for a nice fit and trim look. But you're more than likely going to want to do sealed. Calculating the volume of an irregular shape and then trying to accurately port+tune it is pretty difficult. Have you done fiberglass work before? It's not too terribly hard, but I would definitely try on something a little smaller scale for your first time incase of a screw up, resin ain't cheap //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Dnick454
u the man, ill get on those pics!! and should i use my friends assembled mustang and pics of mine empty, with measurements!
That's for a Mustang coupe it sounds like. I would assume it's quite different with that pocket that the top folds into and all the brackets for the top mechanism.
I dont have a metal strip behind my seats, all of my seats r out, and its wide open from the trunk to the back seat, just a hydro motor right in the middle sitting on the floor
sk1tz0
sk1tz0
cali
sk1tz0
