help: 12" SQL SUB UNDER $200? 1000-1500RMS
AARON30
I have a old school rockford bd1000a1 amp, and i am looking for a 12" sub that will handle the power cleanly, and have good spl and sound quality if possible for under $200...after long research, i am lost!..Please help..
I like the way 12's sound, so thats why i want a 12, and i have an acura legend that i either wanna port through my arm rest in the back seat, or a ported box firing back in trunk...Any thoughts on what would be best would be appreciated...thanks...btw, i have a new Kicker cvr-15d4 and i hate it!!!!
Here is a few i was thinking
1. sundown sa-12 $190
2. pioneer ts-w3004d4 $150
3. audioque sdc2.5 12d4 $160
4. powerbass 3xl 12d1 $125
how much room do you have to work with? I personally would go with 2 mb quart rwe352 15's sealed in 1.5 cubes each, a friend of mine has a pair in a 3.3 cube sealed box of 1200 rms and they sound great and have a decent bit of out put for a sealed setup.
well, i built a 4.2 cu.ft. slot ported box @ 31hz for the cvr and it was loud, but sounded like ***...lol, plus, it def couldnt handle my amp, @ half gain it worked the hell outta it...anyways, back to the box situation, my box was almost immpossible to get in and out of the trunk, another reason why i want a 12"...
16.5"h X 35"w X 12.5"d is what i have to work with approximately..or 3.2 cu. ft. on the 12v.com website calculated
really it doesn't matter much. You can always turn the amp down. People get far too caught up in RMS wattage and power that amps produce. Music tones constantly vary in amplitude and speakers constantly change impedence. Since your biggest complain before was SQ, here are some SQ oriented woofers that can get pretty loud too. Don't get caught up in the idea that many SPL oriented woofers are much louder than most well built SQ speakers, because for daily use, most aren't. They are simply very hard to break and handle high power very well.
Anyway, enough ranting
Parts-Express.com:
or for a bit over budget
DIYCable.com shiva-x
robot underground has a couple of some subs
Hybrid subwoofer TC Sounds Lightning MTX RE HCCA parts 15"
the only bad thing is the $55 shipping for the 15" :/
Hybrid sub using TC Sounds Lightning MTX RE HCCA parts 12"
^^ this one should work out for you!! $195 shipped and 1500w rms
IXL-12 v2 BR [iXL-12 v2 BR] - $149.00 : Mach 5 Audio
CADENCE 10" 2000w COMPETITION CAR AUDIO SUBWOOFER SUB - eBay (item 350344744736 end time Apr-29-10 15:34:43 PDT)
my fav sub for daily, its made in same build house as audioque hdc3, same motor and basket, 1000rms. audiosavings sells out the 12's all the time they have some coming in this week for 179 shipped jump on it. aluminum coil
http://www.bestaudiodeals.com/servlet/the-121/CADENCE-ACOUSTIC-SYSTEMS-/Detail
this is how much cadence sells if for direct from nj
http://www.powermaxelectronics.com/products/pc/viewPrd.asp?idproduct=270&idcategory=13
AARON30
AARON30
BRADENTON, FLORIDA
AARON30
