Hear the bass but can't feel it
So today I tuned my bass amp. Gain and bass boost is all the way down and lpf is about 50-80hz. I'm running 4 15's on 2250 watts and I mostly hear the bass rather than feel it! Someone help //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I don't know the box specs cause it was built like 10 years ago and I bought it from someone. And yea the gain is all the way down. I can turn it up but when I play at low volume I can most "hear" the bass instead of feeling it. I was wondering if there's a way I can change that with a little tuning.
If you hear nothing but bass without the feeling its because the box needs to be ported and bigger for the 4 15s.
Your suffocating your subs.
Look into a new box that is right for all your subs then as you turn up the gain you will feel the bass.
I was afraid someone would say I needed a new box lol. It actually hits hard when I turn up the volume a good bit but at around 10%-15% volume I hear it more than I feel it. It's actually a pretty big ported box. I'm running 4 planet audio z15's on a planet audio tt2250d. With 10g knukonceptz speaker wire...wired to 1 ohm
Now thats different..
You have to understand your headunit does not produce enough voltage until its at 80%+ to produce its full signal.
Unless you get a high powered amp that can be set at such a low volume (by dmm method) then youll get that high bass in low volume.
Turning the gain high while the volume low can do what you want or will clip the crap out of everything.
Your expecting to much from the subs at such a low volume.
so what you're saying is on low volume you can only hear it? Dude you're not going to feel it until you get them moving enough aka high enough volume...
LOL. Some of us have Issues that another can relate too. LOL 😂 😆
24
Get a Wrangler and get naked (you know…the Jeep, not you…none of us want to see that) and you’ll definitely be heard coming. 😉
Your amp may have failed. A competent shop should be able to diagnose the issue in under 5 minutes either way. You didn't necessarily do...
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
341
4Fifteens
4Fifteens
new orleans, LA
4Fifteens
    May 16, 2024
    May 16, 2024
