Headunit or 1/2 DIN EQ for sound quality?
  • 4
Drummer65
Okay so I'm looking to get rid of my piece of $%#@ Jensen flip up HU and either get a new head unit with 3 sets of pre-outs or just run an EQ straight from my ipod. I only listen to music from my ipod so right now i don't really see the point in spending $200+ on a new head unit when i can just get an EQ that will do the same things.
I just got new vifa tweeters and silver flute speakers and they are sounding like crap with the head unit so for the last couple of days i have been just plugging my ipod straight into my crossover which has resulted in much better sound.
I'm only looking to spend about $50 on a EQ but my question is will an EQ have the better sound quality then lets say a $200+ alpine deck?
If so do you guys recommend any EQ's with 3 sets of pre-outs for around $50 bucks?
thanks
toggle switch ftw.
You might wanna look into an Audiocontrol unit if you're gonna be running straight off your iPod. iPods seriously lack in bass. Drop in an Epic-160 or 4.1
Okay well just ordered the clarion but had a question. Because I will be using this as my "headunit", if I turn the volume knob will it adjust the bass also or will I hve to adjust the bass knob as well as the volume knob?
627
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
Drummer65
Drummer65
Newport Beach, CA
Louisiana_CRX
