Hair trick question?..
What size box his much port area and what tune?I'd say 7 cubes tuned to 32 with 100in port area and it souls come easy..
It's about 5.8 cubes net (more than 7 gross) tuned to 32hz with 90^2in of port //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The Hitchhikers Guide to Hairtricks pretty much is...
- High excursion sub
- Don't skimp on the port area
- Tune low
Large amounts of power don't necessarily equal hairtricks, though it doesn't hurt. There are just more important things to achieve more air movement than overall SPL
- Tune low
this, now that i think of it. heard a 1k setup of two 13.5's and it was moving well enough air to get hair moving. the key was the box. was built to as close as you can get to spec and was tuned at 27 hz
As stated above somewhere by the chief groan recipient of the thread, it is all determined by pressure differential. That for some vehicle geometries and sub choices can be obtained using a bass reflex alignment that happens to have a "low" tuning frequency. For other cabin geometries and sub choices, it may require a variant of a transmission line etc. If it's engineered, high excursion may be a byproduct, but not a prerequisite.....nor are high subwoofer Xmax ratings always required. There are vehicles out there that raise scalp fur with nearly no piston excursion.
xmakeafistx
xmakeafistx
Kenosha, WI
snoopdan
