iceteebone
Banned
Makes sense. So i guess the only way is for me to increase the amp gain, or turn up bass boost on the amp?
don't use bass boost. read gain tutorial numerous times.
Should you turn the gain up after you set it according to the tutorial?I know how to set the gain w/ a DMM, im just saying what if its not loud enough (as loud as it was before), after i set it?
No, read what I said again... try to find a way to adjust the subout level seperately. This really isn't your issue anyways...Makes sense. So i guess the only way is for me to increase the amp gain, or turn up bass boost on the amp?
All you have to do is set the gains using the DMM to where they are supposed to be, and it wouldn't matter what headunit you have... your sub would hit about the same.
If your unhappy with the results... then just raise the gains to where you like it, I dunno what to tell you... just realize that you are compromising the reliability (and perhaps SQ) of your sub.
//content.invisioncic.com/y282845/emoticons/rotflol.gif.b453361716769b8110ddefc85ff03cd2.gif you have changed something, (your HU is not the cause of this) if your amp is giving the same sub the same power in the same box that is in the same car and not as loud.i think it's funny the title of this thread is "i have officially reached car audio perfection" but each page of the thread has different problems with the setup.
Just got my last and final component in (Eclipse 5444) and my system is now complete, at say i think its perfect. Not only is it the absolute hardest hitting and loudest system I have ever heard, but the sound quality beats the crap out of every setup i have ever heard, just walks all over everything.
HU - Eclipse 5444
Sub - 12 RE XXX
Sub Amp - Nine.1
Front Stage - CDT EF 61 cfi /tw24
Speaker Amp - Nine.2
Just perfect is all i can say, this should hold me over for like 5 years. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif With my Alpine HU it never sounded right, now it just sounds perfect, it is so deadly accurate with everything song, its crazy, no sub hit happens too long than its suposeed to, simply unbelievable. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif And that HU is amazing.
Obviously you ae doing somthing wrong. Do you even get how to set your gains? Volume at the max you normally would listen to it, EQ settings the way you normally listen to it, Use a 40hz test tone...What could I have changed? All we did was unplug one HU and stick the other one in. Could a wiring error have caused this?
