Guys, i have officially reached car audio perfection
Was the gain set exactly the same(ouput wise) when you installed this deck????
yep. It was much much lower instantly once the new HU was put in, so i had to raise it up alot, and its still not hitting as hard as it was before.
100hz isnt subbass.1V more preout voltage shouldnt make the difference.
It could be how you set your EQ
I think i set it fine? I have 60hz and 100hz at +4 :dunno: non-Fader is all the way up, High pass is 100 and above, low pass is below 100.
Get a **** DMM and get the measurement. Then be done with all these **** threads. I mean cmon kid, you gotta learn to do some things on your own sooner or later.
No, its not set fine
You have it done way wrong
subs should only play under 80hz, if that
Mids should crossover what the sub doesnt play, 80hz or whatever you can set it at.
Those CDT's should be able to take those frequencies just fine
No, its not set fineYou have it done way wrong
They seem to distort when i set the crossover at 80. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif With the Eclipse, you pick one frequency (80, 100 or 120) and it automacally sets the high pass to above that, and the low pass to below that frequency.
MUWAHAHHAHAA.... I have to laugh because it seems like its far from perfect //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif..... LIAR //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif.
so whats the problem then?
this:
If it makes sense, the sub volume wise sounds as loud, if not louder than the alpine, you just can't feel the sub as much.
Set your EQ properly. I don't think you should be setting the crossover at 100. 80 would be fine, if it is "Distorting" when you do that, then there is something else very wrong.
Why does everything you own ****?
What would cause it to be distorting then? It was doing that even at low speaker amp gain.
I dunno....(looks up about 5 posts). //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
and all his stuff sux because he buys junk //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
ls1pimp
ls1pimp
NJM
AVSTANG02
