Guess Its Time for a HOalt :(
I'm runnin 4k on a stock alt and voltage rarely drops below 12.3
4kw is well over 300 amps, and approaching 400 amps when considering your amplifier's efficiency.
Its easy to say "Im running X number of watts on my stock alt", but as Ive said many times before, just because you have a certain sized amplifier hooked up is no guarantee you are pulling that much current. There are a lot of factors that go into figuring your average current draw over time, which is what should be considered here, not some arbitrary number that your amplifier is advertised as producing in ideal circumstances.
probably a 4k boss amp //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I running about 180 amps on a 90 amp stock alt with a second battery in the back and my voltage drops to about the same as yours.
1200 watt sub amp = 120 amp fuse
600 watt highs amp = 60 amp fuse
Why So Cereal?
Invisible Cereal
Why So Cereal?
Drowning in milk
Why So Cereal?
