Supergumby5000
Project: F350 begins...
I need to ground my second battery, and the kinetik manual says its best to ground from negative terminal on battery to negative terminal on startup battery. does it really matter that much where its grounded? I always thought that grounding to the frame somewhere would have the same effect as grounding to the battery. The reason i am asking is if i have to ground to the battery, i need to buy another 20ft of grounding wire //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
