grounding questions...
i could have sworn i read somewhere on this forum that is was better to individually ground your amps to different spots rather than a central spot. So, its actually better the other way around?
The only situation I could see where it would be better to have multiple grounds is when you have amps in the cabin as well as in the trunk. A 10 foot ground isnt the best thing to have. But if the amp up front is small enough it probably wont matter.
that is something different. it is best to find a spot around ur dash, that u can connect the ground wire too. quite recommended but u can always wire up your ground on the harness. As u can see, the wire that the headunit requires, is really small, so there wouldn't be as much affect as the grounds for the amps.
-dante
Huh. My wiring must really **** then. I have a 15+ foot ground for all of my amps. If your amps are in your trunk, yours probably are, too.
-dante
I have installed my haeadunit and attached the ground under the dash, just wondering if it would help to do the other. Thanks for clearing that up.
redlinese-r
redlinese-r
Newton
n2audio
