phrozen5100
Ok, so I decided to get off my lazy ass and test out my new Type RF amps. X1...doesn't turn on...X5...doesn't turn on. Tried out my Hifonics amp and it powered on OK. Everything looks ok, except my pathetic ground. My ground is simply a small screw in the base of my plastic seat...now this ground has worked for several other amps, but I believe it's most likely the problem...unless by some bizarre chance Rockford decided to send me two bad refurbs, haha. That ground didn't work all that well with my Hifonics Zeus, though...it kept going into protect because of undervoltage and that ground likely contributed in a few cases it went into protect. So does the ground sound like the problem to you guys? If so I might just have to order some nice grounding terminals and get real grounds for my amps. Thanks in advance.
