Great deal on 17' of 1/0
was about 2 years ago. maby was bad stock, old style i dunno.. but i have had some real good luck with the soundquest 0g, super flexible and good strand count, has never let me down.. im running 3.5krms sub amp and a 600rms high/mid amp with stock alt and 3 batterys, big 3 and all runs are soundquest 0g and i never dropped below 13.1 full tilt with only 3 batterys and 130amp alt , now granted there both mmats amps that are SUPER efficient and SUPER SQ from both.. but still.. i guarantee i can clamp more then 3.5k on the mmats alone...
What is the difference between the two...???
Also is this cadence wire flexible and easy to work with??
Yeah.
CCA = Copper Clad Aluminum. Basically it's copper wire covered in aluminum. Cheaper to make but less current handling (CCA 1/0 usually can handle 250A).
OFC = Oxygen Free Copper. This is 100% copper and has better handling than CCA. Power ratings for OFC can range from 300-350A. OFC also weighs a good bit more.
I use this wire to power my ZX1500.1 and it works great.
And I agree, it barely fits in the 1/0 power/groud inputs...
Is 17' enough to do a 2door coupe..?? Car is a 03 grand prix. Been awhile since ive ran power wire!! Lol
17 is plenty for a run. I had a few extra feet from doing my blazer.
Yeah.
Wouldn't it be aluminum wire covered in copper?
This is what the website says?????
Features:
Model: 0G100
Gauge: 0 Gauge
Wire Length: 17ft
Cadence Cool Cable Technology
Special Winding Configuration Reduces Unwanted Noises and Maximizes Current Transfer
High Purity Oxygen Free Copper Standing
Incredibly Flexible Yet Extremely Durable
Protective Ultra Soft PVC Translucent Jacket
Braided Super-Flex Design Ensures Optimum Surface Area and Flexibility
Designed for Show Car Performance
1 Foot Markings on Wire Make it Easy to Read and Easy to Cut to Appropriate Size
Ultra-Pure Copper Conduction
High Current Competition Class Power Cable
Eliminates Noise from the AC Line
Shielding From RFI and EMI
Resist Abrasions, Chemicals, and Temperature Extremes
Rated at 110°C (Celsius) / 230°F (Fahrenheit)
Guaranteed to Make Your Amplifier Run Cooler and Sound Better
Stranding: 7 x 7 x 55 x 0.15mm (7 Ropes Consisting of 7 Sets of 55 Strands of 0.15mm Wire)
Color: Blue
Also Available in Red / Black
Features:
Model: 0G100
Gauge: 0 Gauge
Wire Length: 17ft
Color: Blue
Specs are off, trust me lol. This wire is CCA.
Yeah, these are listed as 3ohms nominal and that is why you see the 2.7ohm rating (where they can drop to). There are a number of things wrong...
952
i would recommend placing an amplifier on these to serve any justice at all https://www.polkaudio.com/en/product/mm1-series/mm6502...
(NEW) Pioneer 9" DMH-T450EX Digital Multimedia Receiver with Weblink - $189.99 - Free shipping for Prime members...
The one you linked is still a bit iffy if you intend to push things. Consider the cells are rated 100A Max discharge which means if they're the...
Kangaroux
I put on
Kangaroux
Maine
AnthonyO
