Great amps for the 150 to 200 wrms range
vfl 1880 will give you alot more than 200 rms tho.and they are 40 amp fused i believe ,but if you run it at 2 ohms power for 500 watts rms it will use only 20 amps
The American Bass amps VFL Mini Hybrids are small/compact amps, that deliver a S hit load of power for the money,Worth every penny
The smallest mono amp I have is the Massive Audio BX2. 6.3" x 5" x 1.6" 480W x 1 at 4 ohms. It takes no larger than 8 ga power and ground wire. Off battery power it will make less power, of course, but it's very efficient.
Yeah, these are listed as 3ohms nominal and that is why you see the 2.7ohm rating (where they can drop to). There are a number of things wrong...
878
i would recommend placing an amplifier on these to serve any justice at all https://www.polkaudio.com/en/product/mm1-series/mm6502...
309
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
damiandevika
damiandevika
Trini
Dirtrider4eva
